Is Electroless Ni resistant to Sulfuric based Etch solutions?
Q. I have an Electroless Nickel plated Invar component that I would like to selectively cover with a rust inhibiting primer. The primer manufacturer suggests that the primer will have better adhesive properties if the surface is chemically pre-treated vs. mechanically.
My question: Is an Etch solution (Ferric sulphate/sulfuric acid) safe for the electroless surface?
space systems - Sunnyvale, California, USA
A. Hi Marta.
While electroless nickel is corrosion resistant, those etch solutions are deliberately designed to be highly aggressive and I doubt that it is "safe" even if the plating offers some temporary resistance. I think an organic masking material on the electroless nickel, such as would normally be used as an etch resist, will prove necessary.
If this is a one-time thing, I would definitely use masking. If you are designing a process, however, please test it in the lab rather than designing it based on my untested theory :-)
Luck and Regards,
July 2012
finishing.com is possible thanks to our supporting advertisers, including:
