Iridite Solution Analysis
I am in search of an Iridite (chem film) solution analysis procedure. Can you suggest a procedure?
Kevin Hall- Black Mountain, North Carolina
The manufacturer of the chemical that you use to apply the chem-film coating will be able to supply you with the analysis procedure.
Marc Green
anodizer - Boise, Idaho
