LACQUER APPLICATION TO BRASS NAMEPLATES
I have 4 exterior solid brass plates with engraved name and address details (blue finish). I have already removed the previously coated lacquer that has become very tarnished due to U.V and chemical atmospheric conditions. I have utilized Brasso this on eBay or Amazon [affil links] to remove all the oxidized surface then used a neutral detergent to take away any waxy finish left by the BRASSO.
HOW DO I APPLY A LACQUER TO THESE PLATES (20" x 12") WITHOUT THE LACQUER DRYING TOO QUICKLY?
CLIVE NOBLES
- LONDON, ENGLAND
A. Dear Clive,
After you polish the nameplates with Brasso, you need to chemically clean the piece (i.e acetone this on eBay or Amazon [affil links] Warning! highly Flammable! ) just prior to lacquering. The more thinner you add will cause the lacquer to dry faster, so maybe try 2 parts lacquer to 1 part of thinner. Is the lacquer blushing or fogging because of high humidities? A lacquer "retarder" will slow down the drying time, you can use between 5 and 20 percent, depending on how slow you want it.
Jake Koch
G. J. Nikolas &Co.,Inc.
Bellwood, Illinois
nikolas banner ad
A. I am not a lacquering expert; folks like G.J. Nikolas [a finishing.com supporting advertiser] are. But I think the answer is that the smoother the surface you are seeking, the more coats of more heavily thinned lacquer you need.
Never mind all that, what you need to do is buy a spray can of clear lacquer for cars. Lay your plate flat, and spray away, the lacquer settles on the plate cleanly and clearly, it dries after about 10 minutes for a second coat.
Alan G [last name deleted for privacy by Editor]
sign shop - London, UK
