How to change to automatic anodizing line
I use to bright dip small aluminum parts in a rack. Each rack must be agitated by hand. How can I change to an automatic line if the rack must be agitated?
Ricardo Brakarz- Rio
People lay a ladder-shaped frame along the tanks, supported on rollers, and attach a cathode rocker device to it to agitate it. In my "Solution Agitation & Mixing" article in the Metal Finishing Guidebook you'll see a sketch of this.
