Simple Method for Corrosion Test
Dear Sir,
Could anyone suggest the simple in house method for corrosion test of stainless steel 18/8; 18/0; 420 J1/J2 and iron wire with coating.
Thanks and best regard
Alex HoSeveral tests for stainless steel are described in detail in the ASTM specfication ASTM A380 . You can obtain the standard on-line (for a fee).
Larry Hanke
Minneapolis, Minnesota
