Holes in Hard Anodize
I do hard anodize with internal anodes on tubes. I sometimes get bubbles which demage the tubes by making tiny holes and this is a reason for rejection. Can anybody gives me a solution. The solution is 230ml/l sulfuric acid(technical) 11g/l oxalic acid. Temperature 0 degrees C. Vigorous air circulating.
Moshe Yaakov- Lod Israel
