Gearless Contractometer Use
I have received a gearless contractometer and I an having difficulty using it. The manual that I finally received after the fact is difficult to follow. Do you have any suggestions?
Sandra Hughes- Neosho, Missouri, USA
If you think that the gearless one is difficult, you should try using the older geared unit. Lacking someone to teach you, it boils down to spending enough time with it to figure out how to use it. Kinda like some computer programs.
James Watts- Navarre, Florida
