Copper Plating for Oxidation/Decarb Resistance
Can copper plating be successfully used to prevent oxidation/decarburization on steel that is to be water quenched after austenitizing @ 1550F for 30 minutes? If so, is there a preferred process and thickness?
Andrew DiratsLaboratories - Westfield, Massachusetts
