Epoxy Removal
I am in need of a method to remove cured epoxy adhesive ⇦ this on eBay or Amazon [affil links] from dichromated zinc die-castings. I wish to accomplish the removal with the least amount of damage to the surface or it's appearance. Would there by chance be a product or method available which will soften or remove the epoxy?
Alan GoluekeGolueke Enterprises - Green Bay, Wisconsin, USA
My husband was having a problem removing epoxy from a concrete floor. The thing they have found so far is to heat it with a heat gun ⇦ this on eBay or Amazon [affil links] and scrape it. They aren't allowed to use chemicals, otherwise there is an Aircraft Stripper that works, but is very expensive. About 40$ a gallon and you have to use a activated carbon respirator ⇦ this on eBay or Amazon [affil links] , it is very dangerous otherwise.
Connie Breshers- D'Iberville, Mississippi, USA
