Stripping Silver-Plating from Nickel-Silver
The silver plating is flaking from a tube shaped part made of nickel-silver.
Ultimately I would like a gold finish. Am I correct that the best (tarnish resistant if possible) procedure is to electrostrip the silver plating, mechanically polish the nickel-silver tube, nickel plate the tube, and then gold plate it?
My major concern is the stripping procedure - I'm not sure how to effectively remove the silver plating and activate the underlying metal. I'm also concerned that I might get an uneven coat if I brush plate the long tube, about two feet with a diameter of about an inch and a half.
Any advice would be appreciated.
Joe Cascio- Holtsville, New York
