Inquiry About Uses for Sulfamic Acid
Q. Can I use sulfamic acid for cleaning of boilers and boiler tubes?
Kindly also tell me about major uses of sulfamic acid?
Nadeem Sumair- Islamabad, Pakistan
Q. Dear Sir. supervisor - Ho Chi Minh city, Vietnam 2007 Q. Can sulfamic acid used for Descaling of boiler tubes. If yes , What will be the concentration of Solution & What will be the quantity for 600 kg boiler Jagannathkadam- Bombay, Maharastra, India July 17, 2008 |
A. Dear Sir;
Sulphamic is used for Boiler Tubes Descaling.
Concentration of sulfamic acid
⇦ this on
Amazon [affil links] in a solution is around 8-10% normally; but it depends on scale deposits in tubes.
With Regards
- Ankleshwar, Gujarat- INDIA
August 2, 2008
Q. Dear Sirs,
Please advise the following questions:
(1). Can Sulfamic acid work as reducing agent in wastewater treatment or other industries?
(2). What are the major uses of sulfamic acid?
Thanks & Regards,
Jackie Chiou- Taipei City, Taiwan .R.O.C.
A. (1)I've never heard of anyone using sulfamic acid as a reducing agent. There are some acids that are known as "reducing acids"- HCl is one of them but I'm not sure about sulfamic acid.
(2)Sulfamic acid is used by the pulp and paper industry as a descaling agent because it is a low chloride acid (for use on stainless steel) and will not precipitate sulphate salts (whereas sulfuric acid will).
Terry Wagnerindustrial outsourcing - Kelso, Washington, USA
A. Dear Sir;
Sulphamic Acid is used as;
Descaling Water born & Process Scales in Industrial
Equipments and Process
As Part of Cleaning of Metal, Floor Surface, Household
Equipment, Condenser Etc.
As Chlorine Stabilizer in Swimming Pool
Bleaching Additive In Pulp & Paper Industries.
In Leather Dyeing Process
During Diazotizations in Dyes & Pigments
Manufacturing
Plastic Industries as a curing agent.
We are manufacturer of sulphamic acid of all grades.
Thanks & Regards,
- Ankleshwar, Gujarat, INDIA
Q. Dear sir,
Can I use sulfamic acid in waste water treatment plant as a reducing agent?
Please give details,
environment - Bombay, Maharastra, India.
September 9, 2012
May 2017
Hi H.N. Terry already answered that exact question. Please expand your question to request clarification of his answer, or re-word the question to involve your specific situation, or do anything other than simply repost a question which has already been answered. That's the kiss of death to a dialog :-)
Q. Can I use sulfamic acid ⇦ this on eBay or Amazon [affil links] for cooling tower in chlorine stabilization?
Bhagwan Munde- Parli, Maharashtra, India
November 14, 2012
I am a Senior chemist at a Gold Mine. I am tasked with finding an option for descaling an 8 km line which uses process discharge mixed with cement to paste underground mined stopes.
My question, since the line is pvc/poly and I intend to use 5% sulfamic acid; do I use an inhibitor and name me one inhibitor I can use please?
- Mt. Hagen, Western Highlands Province, Papua New Guinea
October 16, 2013
A. Hi Jacob. My specialty and the site's specialty is metal finishing, and we are not familiar with mining. Still, 5% sulfamic acid will not attack PVC or poly at all. You will find them completely resistant to the acid. Good luck.
October 17, 2013
Using sulphamic acid to clean carbon steel heat exchanger tubes
Hi everyone. I have a question regarding using sulphamic acid as a cleaner. If we have to use sulphamic acid for cleaning of tubes of synthesis heat exchanger at ammonia plant what should be the optimum parameters, e.g., concentration, temperature, etc., considering the fact that tubes of heat exchangers are made of carbon steel. Is using sulphamic acid as a cleaner in this case advisable?
Ammar mustafa- Islamabad, Pakistan
May 9, 2017
A.
You can use sulfamic acid
⇦ this on
Amazon [affil links] at 2%
or HCl 2% with Thiourea
⇦ this on
Amazon [affil links] as inhibitor.
Chemical Engineer - Alexandria, Egypt
May 15, 2017
