Seeking Teflon Coating m/c Required
Most of the kitchen utensils are made of stainless steel, or iron or some times even aluminium.
I want to know if there is a supplier who can supply me a teflon coating machine, which can do a teflon coating on utensils of various sizes (usually pan size). Can a single machine be used to coat different metals like mentioned above. May be in a batch or a first in first out basis, or one at a time basis.
Indiver Dwivedi- Pune, Ms, India
There are different kinds of Teflon coatings. From just one coat system to 3 coats systems, but you will always need to make a gritblasting onto the surface before the primer / coating. And after the coating you must to cure in the oven at 400ęC approx.
Jordi PujolMASKING - Barcelona, SPAIN
