Thread 82/47
Restoring Old School Desk
Just purchased an old school desk - wood top with metal frame. The metal frame is brown rusty - what should I do to restore this.
Gene Williams- Wilmington, Delaware
publicly reply to Gene Williams
I have a large version of yours, I believe. First I am going to disassemble it, then I am going to strip (paint remover ⇦ this on eBay or Amazon [affil links] )the old paint from the metal frame and wet sand the rust off with WD-40 ⇦ this on eBay or Amazon [affil links] . I will then remove the WD-40 residue and paint the frame with a rust inhibiting primer, then a couple of coats of a good black enamel (spray paint). I will strip the varnish, if any, and sand the wooden top. Next comes the stain of choice, oak, cherry or walnut with sanding between each coat. The finishing 2 coats of a good polyurethane with sanding between each coat. Finishing with a couple of coats of paste wax.
R.F.Monaco- Winter Park, Florida, USA
publicly reply to R.F.Monaco
That "wooden" top you have may actually be a formica type surface and if you sand it down (as my wife did) you will mess it up.
P. L.- Dallas, Texas
publicly reply to P. L.
