Aluminum Casting Squeak
I have an application where two 356 aluminum alloy castings are in contact with each other in a clamp type mechanism on our product. There is slight movement in the assembly which cannot be eliminated and is inherent in the design. This movement creates a loud "squeak" similar to that of an old rusty bed. I have tried type 3 ano with a teflon dip which helps but only temporarily.
Any suggestions on a coating which would eliminate the "Squeak"? Would you suggest I coat one of the parts or both?
Paul Dickie
- Fresno, California
Dry film lubricant on one or both of the parts might help.
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke banner
