Non-Conductive Corrosion Coating
We are looking for a protective coating for high speed shafts operating in Cl2,HCL, F2. There is no friction just centrifugal loading. The coating must be non-conducting.
Shawn GibsonRevolve Magnetic Bearings - Calgary, Alberta, Canada
Everbrite Protective Coating is a non conductive clear coating that will protect from oxidation, corrosion and other damaging elements. It may fit your needs.
Teresa SedmakEverbrite Coatings
Rancho Cordova, California
