Where to Buy Liver of Sulfur
Can anybody tell me were I can buy Liver of Sulfur? I am working on an old house and I lost the screws to some of the door hinges. I want to try to make the new brass screws prematurely tarnish so that they won't stand out so much. Any help would be greatly appreciated.
John D'Alessandro- Wayne, New Jersey
Try RioGrande [Albuquerque, NM]
Neil BellAlbuquerque, New Mexico
Hi John,
Make your own!
Mix 50% solution Caustic 1 to 1 with water
Bring to a low boil
Add 1/2 to 3/4 lbs sulfur
⇦ this on
Amazon [affil links]
per 1 gallon of solution and continue to boil until sulfur is dissolved.
(Sulfur is readily available over-the-counter at most pharmacies)
Gayle CoffeyMetalx Specialty Products / Ronatec
Fallbrook, California
Any special type of Caustic? And where do you get that?
Chris Jensen- Lake Forest, Illinois
Not to argue with someone as smart as Mrs. Coffey, but this procedure of boiling liquid caustic is for experienced industrial users with personnel protective equipment and hazmat training, Chris. '50% Caustic' means liquid (sodium hydroxide) which is marketed at that strength in 55-gallon drums by chemical distributors ⇦liquid caustic soda in bulk on Amazon [affil link] . Good luck.
Contenti.com has Liver of sulfur $12.90 for 1/2 lb can and it comes in lump just dissolve in warm water! Good luck.
Massiel F- Coventry, Rhode Island
March 6, 2008
Liver of sulfur won't patina brass. It only works on copper and silver.
You will need a brass toner with selenium in it. Rio Grande in Albuquerque has it. Good luck!
- Wilmington, North Carolina
September 4, 2008
Try going to Michaels and getting a patina solution/paint for brass. Even just rubbing some brown/black latex paint on it and rubbing it lightly before it gets really dry may help too. Much less toxic and not at all dangerous for your health
Nancy Luna- Minneapolis, Minnesota
December 18, 2008
