Removing Heavy Brass Oxidation
Howdy,
I am trying to clean heavy oxidation(thirty years worth)from various brass parts on a boat. Most of the pieces can't be removed. I have tried quite a few of the standard products, Brasso, Flitz, Barkeepers Friend ⇦ this on eBay or Amazon [affil links] , but the results are minimal.
Do you know of any products or methods that will speed up my work?
Seth Anderson- Seattle, Washington, USA
I, too, am having trouble removing oxidation from a pair of floor style candle holders. The only thing that I have found that will remove it (and this takes a lot of time) is fine 00 steel wool ⇦ this on eBay or Amazon [affil links] . Most people do not understand that oxidation is not like tarnish. Brasso ⇦ this on eBay or Amazon [affil links] , etc. will not remove oxidation. After using steel wool, I then use Brasso, etc. to polish. If you hear of something better, please publish on internet. I will be watching.
Betty T. Caton- Knoxville, Tennessee, USA
Hi, folks. Although it's very easy on people, one of the most aggressive things for brass is vinegar ⇦in bulk on eBay or Amazon [affil links] + salt + flour. Don't use it on delicate stuff because it's aggressive, and plan on going over it with a commercial polish like ⇦[this on eBay or Amazon affil links] because it will usually leave brass rather raw and orange. Good luck.
August 18, 2009
