Dielectric Layer over Au
I have 500 µm diameter Au surface patterned using photolithography technique. I need to put down a dielectric layer to protect that gold for the remaining fabrication. I am seeing delamination of PECVD oxide (1 um) from the Au surface with a thin layer of Ti as an adhesion problem. I was wondering if there is a way to eliminate this adhesion issue.
Chris
- Ithaca, New York
Your problem may be more of stress in the oxide film than adhesion itself. Deposit a series of thinner films and see if peeling goes away. If it does, see if increase in PECVD process pressure could reduce the stress. I don't recall all the details but that may work. If stress is not the problem, metal surface preparation needs to be looked into.
Mandar Sunthankar
- Fort Collins, Colorado
