Crack on Small Galvanneal Samples
I have been conducting the annealing (air cooling) of hot dip galvanized steel plate (1mm thick) then I found cracks all over the surface perpendicular to steel base.
My hypothesis were:
1. the air cooling rate was too high or;
2. the sample was too small
Muhammad Abduh
- Bandung, Jawa Barat, Indonesia
