What is ELECTROPHORETIC LACQUER?
Q. We are somewhat confused by the definition of electrophoretic lacquer. Could you please explain in layman's terms how it is applied and any other tech details to help me decide if it is better than oven baked lacquer?
STEPHEN ROBERTS
- Devon, UK
"Electrocoating: a Guidebook for Finishers"
by Electrocoat Association
ced1_electrocoating2010
AbeBooks
"Handbook of Electropainting Technology"
by W. Machu
A. Hi there,
Electrophoretic lacquer and oven baked lacquer you mentioned may not be necessarily two different things. Lacquer coating may be applied by any route from a simple dipping to the more sophisticated electrophoretic method (EPD: electrophoretic deposition) as indicated. It is understood that drying in air flow or with the further application of heating/baking (such as in a oven) is usually necessary to remove the lacquer solvents or moisture residue.
As a general coating technique, EPD relies on the migration and deposition of charged particles from a solution onto an opposite-polarity substrate (workpiece) under the application of an external power supply. The solution must be colloidal type, and depending on the solution pH, the loaded suspension particles (oxides or other ceramics) or macromolecules (such as acrylic resins) can acquire either positive or negative surface charges on surface, which make them mobile under E-field. EPD differs from processes such as electroplating in that it deposit fine particles as opposed to ions. One of the most established industrial applications of EPD is the formation of paint coat [primer] on car bodies. In terms of merits, EPD has high throwing power, thus coating is more adherent and better able to cover small holes or crevices than dip coating.
Hong-Wei Wang
- Manchester, UK
Kindly please need your feedback.
Is it possible to color the nickel plated parts after process called Electrophoretic Lacquer?
xenicinth
Xenicinth Eng
Engineer - Malaysia
August 15, 2008
A. Hi, Xenicinth. If I understand your question correctly, yes. In fact, a lot of brass colored components such as lamp parts contain no brass, but are actually nickel plated and then electrophoretically lacquered with a lacquer that has a brass colored tint.
August 19, 2008
A. Hi,Xenicinth
CED is basically cathodic electrodeposition lacquer which is clear. We may convert into colored clear or opaque by help of colors. That means we can do the color coating in any of the conductive metal substrate.
Chandresh Varsani
- Rajkot, Gujarat, India
August 22, 2008
ACRONYMS:
GPC or PGC = potassium gold cyanide
We are doing Gold plating on jewellery items by GPC. But the after some time the plated items are deplated. Is it possible to do EPD to increase life and adherence of items in terms of EPD process.
Yash Sonar
elecroplaters - Nandurbar, Maharashtra
December 29, 2015
