302 Stainless Steel Etching
What is the best method of etching 302-304 stainless steel for the purpose of promoting adhesion of flexible polyurethane rubber?
Steve Petzold- Tualatin, Oregon, U.S.A.
Solvent clean the area, then abrasive blast to a depth of 20%-25% of the thickness of the material to be applied. This should give the surface area and "tooth" required for proper adhesion
Dan Lane- Franklin Park, Illinois USA
If blasting is desired, one should use virgin blasting media as not to contaiminate the stainless steel surface and make it prone to corrosion.
Michael Liu Taylor
specialty stainless steel distributor - Dallas, Texas
