Seeking Slurry Hone (or comparable) Process
Need slurry hone or comparable finish:
- Hole diameter: .020±.004
- Material: 6061-T6 Alum Alloy
- Thickness: approx 1/4"
- Qty: Each part has a 43 hole pattern / lots of parts
- Over all part dimensions: 15.5 sqr x 3.18 thick. Area requiring slurry hone is recessed.
- Phoenix, Arizona
Extrude-Hone is based out of PA, and has some jobshop capabilities that should fit your needs.
Christopher J. Griffin- Greenville, South Carolina
Extrudehone is good for I.D. and holes; however, if you are more concerned with a surface finish and exit points of holes, you might want to compare and look at some high pressure systems that are specifically made to deburr parts.
AF Kenton
