Seeking Tin-Oxide Coated Soda-Lime Glass
We are a company searching for soda-lime glass coated with transparent conductive tin-oxide, thickness 1.1 or 1.8 mm, size 300 x 300 mm. Quantity 2000 sheets/year. For solar cells manufacturing application.
LABOURET
SOLEMS - PALAISEAU - France
I believe that what you are looking for is called ITO or Indium-Tin-Oxide. It's the coating used on LCD displays for the conductive layer. It's deposited on the glass sheets by evaporation in a vacuum chamber. Look for Indium, ITO and Evaporated Coating on the internet.
C. Barry Ward
- Atlanta, GA, USA
