Chemical Formula for Copper Plating
Hi.
I am wondering what the chemical formula for copper plating is. I am using CuSO4 as the bath. If you can answer this question I would be most appreciative.
Patrick Ryan- Sudbury, Ontario, Canada
The chemical formula for copper plating is Cu0 unless I misunderstood you.
Hello. I was wondering what is the formula of the element copper? and what does formula mean?
Indya S.student - Perth, Wa, Australia
Middle English coper, from Old English, from Late Latin cuprum, from Latin Cyprium (aes), Cyprian (metal), from Cyprius, of Cyprus, from Greek Kuprios, from Kupros, Cyprus.
Cu would be from the Late Latin Cuprum
- Bogart, GA, USA
