Need Product to Remove Copper Oxidation
I'm a chemical engineering and I work with copper in my job. I need a copper cleaner, a product that removes the superficial oxidation in copper. I have used nitric acid, but the oxidation remain. Thanks
Marcelo Tirelli
- Lorena, Sao Paulo, Brazil
If you can handle HNO3 you can probably handle this solution:
120 g/L sodium persulphate
30 mL/L concentrated sulfuric acid
This is actually a copper etch; there will be metal removal and the resultant surface will be active. A benzotriazole this on eBay or Amazon [affil links] or citric acid this on eBay or Amazon [affil links] solution can prevent further tarnishing.
James Totter
James Totter, CEF
- Tallahassee, Florida
