How to oxidize copper sheet to produce colors?
Q. HELP! I saw a process done once where a man used different chemicals (acids) to create a reaction to a sheet of copper to cause the surface to become iridescent. Each chemical he used caused a different color or multiple of colors to appear on the sheet of copper. He would use a very large sheet of copper and create this surface. Afterwards he was able to cut the sheet of metal down and adhere it to certain surfaces like wood so the wood was covered in this patina type surface. Does anyone know what this process is called and how I can accomplish this myself?
Vicki Vowell
- Ft. Worth Texas
A. If you want sheet copper to appear 100 years old immediately use 0000 #0000 steel wool this on eBay or Amazon [affil links] and muriatic acid this on eBay or Amazon [affil links] , just rub copper with wool and brush on muriatic acid (not diluted) and the next morning it will be green.
Jasper M Chambers
- Beckley, WV
! Thanks Jasper!
But readers should recognize that the internet is like a one-room school house where you'll hear about stuff you may not yet be ready to do. Muriatic acid is strong and dangerous stuff, not to be used if any children or animals are around, and only while wearing goggles this on eBay or Amazon [affil links] and rubber gloves this on eBay or Amazon [affil links] as a minimum. And only if you prepared to very very slowly and very patiently neutralize it with baking soda [in bulk on eBay or Amazon [affil links] after use.
