Powder paint curing problems
#1. We have some complicated bent parts to be powder painted, we are facing problems of under coating in the not easily accessible areas. Ours is CORONA type gun.
#2. What should be the curing temperature for "textured finish" powder.
#3. We want to know the availability of low temperature curing powders ?
We are looking for a "Powder Paint with low curing temperature" to reduce power cost. We require a commercial quote globally.
S.V.Nanda
Otis elevator co (ind) ltd. - Bangalore, India
First thing you should be using Tribo Guns not Corona.
The curing temp for texture finishes will vary from one powder to the next. I would try 400 to 425 °F for 20 to 30 minutes.
Low temp cure powders are available from most if not all powder manufacturers.
Good Luck! Scott Jones
Advanced Finishing Systems - Winnipeg, Manitoba Canada
First of all, if you cannot use a tribomatic gun turn the kV down on your gun, alternatively you could try to pre-heat your substrate.
Curing temps for texture powder coatings vary from 160 °C x 10 mins to 220 °C, dependent on the system.
You can get powder coatings that are able to crosslink at 140 deg C x 12 mins. Alternatively you could assess the possibility of UV cured powder coatings. These powders are available from most major powder producers.
Drew
- Lincolnshire UK
Ed. note: Thanks, Drew. Full name next time please.
