Coating glass rods with indium-tin oxide
I am interested in coating glass rods with indium-tin oxide in order to eventually have an impedance of about 1 Megohm/meter for application in electron spectroscopy.
Any hints for technical procedures or alternatives in terms of powder to be used is welcome.
With kind regards
Siegbert Hagmann
GSI - Darmstadt, Germany
The method you could use is called spray pyrolysis. It is a relatively simple method that uses a small spray booth and a hot solution. There are several expired patents from 1960s onward related to solar cells and window glass that will help for details.
Mandar Sunthankar
- Fort Collins, Colorado
