How to vaccuum metallize wood
1)how do I vaccuum metallize wood?
2)What lacquer do I use?
3)Will the coat last long?
Xavier Kuriyan- tumkur Karanataka, India
A lot will depend on the quality of wood and its outgassing properties in vacuum. Place the wood (about 10 to 15 cm dia. x 20 to 30 cm long) in vacuum under milliTorr pressure and see if the evacuation holds when all valves are closed. If you see the pressure rises more that a couple of milliTorr per min, you have a problem. If all is ok, find a suitable varnish, apply it and cure it thoroughly.
Mandar Sunthankar- Fort Collins, Colorado
