THIXON coating?
I'm looking for a coating called THIXON adhesive coating.
Does anybody an idea of what is it?
Jordi Pujol- Barcelona, Spain
I found numerous references to 'Thixon' on the web using the Google search engine. Thixon is a specialty aerospace adhesive.
Sjon Westre- Minden, Nevada
IS AN ADHESIVE USED FOR GLUE DIFFERENT RUBBER TO METAL IN VULCANIZATION TIME. HAS INDUSTRIALS, PHARMACEUTICAL, AND FOOD USES. HABLO ESPA-OL.
Piero Gambino- BSAS, ARGENTINA
Thixon is a specialty adhesive that is applied to metals and plastic inserts. The inserts are then placed in a mold and rubber is molded around it. The thixon reacts with the vulcanization process and bonds the rubber to the metal/plastic component.
David Cox- Port Huron, MI, USA
Thixon bonding agents are/were produced by Morton, which I believe was bought by Rohm & Haas.
Hope this helps,
Greg Rawlinson- Preston, England
