Anodizing 201R5
Our anodizer is using the following specification 201R5 for our aluminum components. Does anyone know what this specification means.
Ray Carter
- Shokan New York USA
First of three simultaneous responses--
201R5 is an Alcoa designation for a .0002" thick anodize with a brite dip pretreatment.
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke banner
Second of three simultaneous responses--
Its basically a specified designation for the type of finish you are getting. The 201R5 and other coatings from the Aluminum Association (dear god I hope I have that right, its very late :-)) have designations similar to this such as 202R1 and so on and so forth. Basically it would amount to something such as this :
201R5 = Standard Sulfuric Anodize 2.5 micron (or .0001 thickness). Thats the 201 part, the R5 stands for highly specular finish is what the chart from anodizing.org states. Check it out under the reference guides section. That'll give you a little more insight into this.
Matthew Stiltner
plating shop - Toledo, Ohio
Third of three simultaneous responses-- 2000
The spec you reference is from Alum. Assoc. I do not have 205 R1 but here are the ones I do have.
ALUMINUM ASSOCIATION ANODIC SPECS FOR ALUMINUM
David A. Kraft
- Long Island City, New York
Is there an industry or military standard for bright dip? Something to call out in a print, i.e. "Chemical etch per _________."
Peter Hall
- Ellicott City, Maryland, USA
November 8, 2012
A. Hi, Peter.
Someone else may have a better answer for you, but I am not aware of military or ASTM/ANSI standards for bright dipping. We appended your inquiry to a thread which offers some good leads on the R1 and R5 standards from the Aluminum Association. And there is another well known bright dip procedure known as Alzak, formerly an Alcoa standard, and discussed in letter 55394. Finally, there was another proprietary formula for bright dipping from Albright & Wilson, known as "Phosbrite" -- you could try googling that as well. Good luck.
November 12, 2012
