Skin products affecting dyed anodizing?
Q. We are a machine shop with our own Type II anodizing line, producing a consumer product (safety shaving razor). We have recently had several instances where customers have had the dyed colour "disappear" from their product. In some cases the way the dye has disappeared looks like it is primarily in the areas where there is the most skin contact (hand and face). The appearance is similar to what it might look like if someone colored the product by using a permanent marker, and then with use the marker wore/smeared away. The affected products are from different batches and timeframes. We have not been able to learn anything helpful from the customers.
We have received some of the products back, and the coating thickness, dye stain test, etc. all test as acceptable, so it seems to us like the anodizing was done properly.
I'm wondering if there are known skin related substances, either natural bodily oils/fluids or common skin products (or ingredients in such products), that are known to do this to dyed anodizing? Any other thoughts on a cause for this?
- Cambridge, Ontario
October 31, 2024
![]() Aluminum How-To "Chromating - Anodizing - Hardcoating" by Robert Probert Also available in Spanish You'll love this book. Finishing.com has sold almost a thousand copies without a single return request :-) My guess is, that the shaving cream is somewhat alkaline, and more so than the anodizing, or rather sealing, can cope with. And therefore the dye can be removed over time, due to the pore no longer being sealed, and thus the dye and pore is exposed to the shaving cream. It should be fairly easy to test, either by exposing one of the parts to prolonged exposure to shaving cream (Different variants probably, along a wide price range), or measure the pH of shaving creams to see where they are on the scale, as anything over 9 is an issue. Technician - Horsens, Denmark November 1, 2024 A. To begin with, if I were you I would attach pics of problem which you mentioned despite your good explanation of problem. In my opinion, there are two possible reasons regarding source of problem; - TURKYE Sakarya November 1, 2024 |
