Electroplating: Role of a chemist
Tip: Readers want to learn from Your Situation  🙂
        many readers skip abstract questions.
Q. I want to know the role of a chemist in the electroplating of sanitary ware, as well as what chemical and physical tests he performs.
Mahmoud Ibrahim
- Egypt
September 1, 2024
"Electroplating Engineering Handbook"
by Larry Durney
EEHcover
or eBay or
A. Hi Mahmoud,
A successful plating facility probably requires a plating laboratory supervised by a chemist who would do titrametric and other tests to insure that the processing solutions are in proper balance and that the waste products are properly neutralized for discharge, and who would assist in developing strategies to prevent or resolve any plating defects.
Q. What's Nickel seal in brass electroplating?
Mahmoud Ibrahim [returning]
- Egypt
September 4, 2024
Usually available on eBay;
sometimes on
AbeBooks or Amazon
(affil links) mfg_online
A. Hi again,
Sorry, I have no idea what you are talking about. Perhaps it's a translation difficulty and you are inquiring about nickel electroplating of a brass substrate?
Please try to make your question a full paragraph, with where you heard this term and why you care about the answer. Thanks.
Q. What is the preparation of chemistry lab for Electroplating process and what devices, equipments, solution, chemicals, and other tools used for the lab.
- Egypt
September 10, 2024
Ed. note: Our assumption is that Mahmoud's e-mail is not working correctly such that our responses to him are not being seen. But for the benefit of other readers seeing this question, it is probably impossibly broad.
