Smut on powder coated parts after curing
SUGGESTED POWDER COATING BOOKS
for Shops & Engineers
powdercoat_pietschmann2023
"Industrial Powder Coating: Basics, Methods, Practical Application" by Judith Pietschmann (2023)
powdercoat_liberto2003
"User's Guide to Powder Coating" by Nicolas Liberto (2003)
powdercoat_utech2002
"High Performance Powder Coating" by Bob Utech (2002)
powdercoat_liberto1994
"Powder Coating. The Complete Finisher's Handbook" by Nicolas Liberto (1994)
powdercoat_sys_lehr1991
"Powder Coating Systems" by William Lehr (1991)
powdercoat_tech_harris1976
"The Technology of Powder Coatings" by S.T.Harris (1976)
"Fundamentals of Powder Coating by Emory Miller & David Taft (1974)
Q. I have a problem with high gloss black. It usually happens on thick parts, die cast iron and die cast aluminum when I apply high gloss black powder on parts.
After curing there is some kind of grey smut all over the part. It can be wiped off with clean cloths or polishing machine. But sometimes I need to do a very hard wipe to get this smut off. Result is less gloss, less shine after wiping.
I need help to fix this problem please. I've been searching answer for a while but seems like no one has this problem.
The result came up as photo attached.
61667-1
My coating procedure is:
- degrease
- Strip old color by chemical
- Rinse by DI. Water
- Dry by air blow gun
- Sandblasting
- Rinse by Di. Water
- Dip in Zirconium bath
- Dry by air for 12 hours+
- Heat up in gas oven before coating at 120 °C for 15 minutes
- Wait for temperature decrease
- Apply powder color
- Bake at 200 °C for 15 minutes
Kantinon Worawutwakin (Bell)
- Phitsanulok Thailand
May 14, 2024
