Anodizing a Weldment of Different Aluminum Alloys
"The Metallurgy of Anodizing Aluminum"
by Runge & Kaufman
anodizing_runge2018
Q. I am a manufacturing engineer at a company that manufactures aluminum engine oil coolers. We vacuum braze cores. The components in the cores are made from 6061, 3003, and 4004 alloys. After building the cores we weld A356 cast components to the cores. The fin construction in the core is similar to what is seen on a radiator. We are considering sulfuric anodize for corrosion protection for this product. Is it possible to anodize a product that contains 4 different aluminum alloys?
Trista Schroeder
- Troy, Indiana
October 14, 2021
A. Trista
Yes it is possible to anodize a part that is consisting of 4 different aluminum alloys, but the results may not be favorable. the 4 alloys you plan to use anodize differently meaning some will anodize more quickly while others will take more time. what this equates to is varying thickness from alloy to alloy and a good chance of color variation. you might be able to get away with hard coating the parts but you could end up with a collage of different colors because each alloy takes on a different color during the hard coat process.
the ranges of color may be more dramatic depending upon the thickness you are wanting to attain.
Philip J. Verzal
supervisor - Cicero, Illinois
Saporito Finishing Co.
saporito
October 15, 2021
thumbs up sign Thank you Philip for the great information.
Trista Schroeder [returning]
Manufacturing Engineer - Troy, Indiana
December 30, 2021
December 28, 2021
A. Hello Trista,
In addition to the other excellent advice, will you have the assembly heat treated after welding? This will not improve the colour coordination of the various alloys when finished, or how quickly they build in the tank, but the welding itself creates zones where anodizing is unpredictable as temper is changed, and welding rod is a different animal entirely... It's like you've added an untreated casting into a wrought assembly. So the corrosion resistance across the finished assembly will be wildly variable, and it may be quite a sight even just visually. My shop refuses multi-alloy assemblies flat out, and if something arrives with welds, there is additional communication prior to accepting the job, because of the issues both functional and aesthetic that always arise.
rachel_mackintosh
Rachel Mackintosh
thumbs up sign Hi Rachel. No, the assemblies will not be heat treated prior to anodize. Thank you for the excellent information regarding possible adverse effects.
- Troy, Indiana
December 30, 2021
