Minimum service temperature for electroless nickel plating
Q. Can anyone tell me or point me to data pertaining to the minimum service temperature for electroless nickel plating?
Substrate would be 6061 T6 Al. Electroless Nickel per AMS2404, GRADE A, .001" CLASS 4 adhesion bake. The part would cycle between -80 °C and room temperature possibly on a regular basis.
JAMES STRUCK
- LANCASTER Pennsylvania
April 29, 2021
A. Hi James. I see no warnings against low temperatures for electroless nickel in such references as "Electroless Plating" [on eBay , Amazon, or AbeBooks affil links] , Dini's "Electrodeposition" [on AbeBooks, or eBay, or Amazon affil links] , or Gawrilov's Chemical (Electroless) Nickel Plating[this on Amazon, ... on AbeBooks affil links]. And -79 °C isn't much colder than dry ice, whereas electroless nickel has been used at -183 °C to protect titanium from liquid oxygen.
So the question will probably not be whether electroless nickel can reliably endure -80 °C, but whether you can get sufficient adhesion to aluminum to withstand the high coefficient of expansion of aluminum vs. the low coefficient of expansion of electroless nickel. Hopefully some reader will volunteer some practical experience but, pending that, it would seem to me that if the temperature difference from -80 °C to room temperature is 100 °C, and if you can use electroless nickel plated aluminum at 100 °C higher than room temperature, then you should be able to use electroless nickel in this application.
April 2021
thumbs up sign Make sense Ted. Thank you very much for your valuable input!
James Struck [returning]
- Lancaster Pennsylvania
April 29, 2021
Q. Hi James,
We're looking into potential cryogenic applications for electroless nickel and I wondered how you got on with the above mentioned application and if you'd be happy to share your findings?
Kind regards
Chris
Chris Brown
Technical Director - Chesterfield United Kingdom
January 31, 2022
