No passwords, No popups, No cost, No AI:
we earn from 'affiliate link' purchases, making the site possible
Sound technical content, curated with aloha by
Pine Beach, NJ
Copper Plating from an ammonia Solution
Q. Hello I'm Jordan,
I have been doing electroplating as a amateur hobby for a while now and I have a question. I've tried looking up the answer but either I am not wording it right or I have overlooked it. I have made an aqueous solution of copper and ammonia. Would I be able to use it as is as a solution for copper plating? And if no, is there a way I can neutralize the ammonia this on eBay or Amazon [affil links] closer to a safe pH thats usable? What answer am I not thinking of or overthinking? And I am an hvacr tech so my shop does have a hood fan in it so vapors are handled in a safe manner. Thank you.
Jordan Rusk
- Centralia, Illinois
January 30, 2021
61204-1ext
A. Hi Jordan. I'm not familiar with any industrial copper electroplating being done from an ammonia solution, but apparently it is possible ==>
But I suspect that chloride or sulphate (as per the article) is required for conductivity if for nothing else. So where did you find instruction to try ammonia as the electrolyte, and why are you trying to do this? If you're just mixing random stuff together, an explosion is probably at least as likely as a workable electroplating solution :-)
Please tell us what motivates your efforts on this so we can help more effectively.
January 2021
A. Add some tartaric acid this on eBay or Amazon [affil links] and water, pH must be 8-9, and then it must work. Alkaline tartarate bath is one of the oldest cyanide free coper plating baths.
Hope it helps and good luck!
- Zagreb Croatia
January 31, 2021
