Plating chrome on a nickel substrate
Q. The substrate is 100% nickel (0.25 mm thickness). The finish is bright chrome (.3 um thickness). Given the Ni substrate, what are the recommended sub-layers (semi-bright Ni / bright Ni) to achieve corrosion protection for an exterior part application? Please suggest plating layer and thickness for each. Thanks for your input.
Robert Cinquina [returning]- Mays Landing New Jersey
December 2, 2020
A. Hi Robert. I see no previous inquiries on our site about chrome plating onto a nickel substrate, and I have never seen it myself. Until someone who has done it replies, I can only offer some assumptions ...
I don't think you need to worry about the corrosion resistance of the nickel, and if you did, I don't see how nickel plating it would increase its corrosion resistance anyway. So I think you're looking for bright nickel of about 15 microns for decorative reasons. But the nickel substrate will surely be passive and will require a Wood's Nickel Strike before the bright nickel.
December 2020
- Mays Landing New Jersey December 2, 2020 A. You did not say the size of the part. Since it is very thin, the part will not be very conductive and the Woods Strike will "pile up" on the high current density outer edges. You might have to do some shielding to get the strike to activate the inner part of the thin sheet. Be sure to make contact in several places to distribute the current ![]() Robert H Probert Robert H Probert Technical Services ![]() Garner, North Carolina ![]() December 2, 2020 |
Well noted, thanks.
December 3, 2020
A. Robert Cinquina
you can plate chrome on nickel substrate -- REPLATE PROCESS
1) Nickel buff parts
2) CLEAN PARTS WITH SOAK AND ELECTROCLEANER
3) RINSE
4) DIRECT CURRENT IN ACID SALTS CHEMICALS
5) RINSE
6) WOOD'S NICKEL STRIKE
7) SEMI BRIGHT NICKEL
8) BRIGHT NICKEL
9) PARTICLE NICKEL
10) CHROME ACTIVATOR
11) CHROME PREDIP
120 CHROME PLATE
Popatbhai B. Patel
