Remove hand sanitiser stains from hot dip galvanised material
Q. Please advise: as per the government instruction we have spread sanitiser on the hot dip galvanised material to kill pandemic virus Covid-19. Now what happened after two days later is we found etching mark (White dots) on the hot dip galvanised material.
61110-1
It looks like white rust or wet storage stain. Please suggest how to remove these stain marks from the material.
Gopinath Harichandran
- THANE, India
May 17, 2020
A. There seems no good reason to spread sanitiser on a zinc surface after galvanizing. Are you suggesting this virus will withstand the process?
Now to clean up after making this mistake:
A dilute solution of citric acid this on eBay or Amazon [affil links] followed by a water wash might work. Try a small area first. It works OK for standard white rust.
Is your customer claiming this material does not meet a quoted standard agreed with the galvanizer prior to order?
geoff_crowley
Geoff Crowley, galvanizing consultant
Crithwood Ltd.
Bathgate, Scotland, UK
crithwood logo
September 1, 2020
