Electropolishing Solution Excessive Foaming
Q. HI
MY NAME IS KATHY AND I AM LOOKING FOR ANYONE WHO HAS EXPERIENCED THE SAME PROBLEM I AM UP AGAINST HERE. PLEASE HELP IF YOU CAN.
ELECTROPOLISHING SOLUTION PROBLEM EXCESSIVE FOAMING OF BATH. IS THERE A ANTIFOAM SUPPRESSANT KNOWN TO ANYONE? COMPOSITION OF BATH : PHOSPHORIC ACID, LACTIC ACID AND SULFURIC ACID.
THANK YOU
KATHY KOZUMPLIK
- CLEVE. OHIO USA
A. Question to you, is your bath homebrew? If so why the lactic acid? jon
Jon Quirt
- Fridley, Minnesota
A. Kathy: Foaming of electropolishing baths can also be caused by drag-in of organic materials, such as lubricating oils. Are you cleaning the parts adequately before electropolishing?
We have some foam suppressants available, but the most effective treatment is to remove the organic contamination.
Contact us via the Suppliers Directory on this web site for additional details.
Ed Bayha
Metal Coating Process Corporation - Charlotte, North Carolina
