Wastewater from Aluminum brightening
Tip: Readers want to learn from Your Situation 🙂
(little can be learned from abstract questions, so many readers skip them)
Q. I would like to know about the technologies used to treat the wastewaters produced during aluminum brightening using phosphoric acid. I've been looking for such information but I still cannot get a real industrial situation. Does anyone know about it or where to get information from?
Any information will be greatly appreciated.
- Spain
A. Generally aluminum discharges are not regulated and your concern will be for the alloying metals in the material you are bright dipping--probably copper. But phosphate discharges can certainly be an issue as well. Sometimes a conventional end-of-pipe neutralization with an alkaline reagent, and then clarification, is all that is required.
