Need Hard, Inexpensive, Corrosion Resistant Stainless Steel
Q. Here we are using stainless steel SS201 in the spin tube drive assemble in laundry machine. We are facing wear damage in the tube surface because of low hardness. So we need an alternate cost effective material with hardness 35-40 Hrc, and it should withstand salt spray of 500 hours. So please suggest a low cost material to satisfy our need.
Manikandaprabu Janarthanam
- India
March 20, 2019
Q. Which stainless steel grade has both hardness 35 Hrc and corrosion resistance for sea water application?
Manikandaprabu Janarthanam [returning]
- neyveli TS, India
August 27, 2019
Dear Manikandaprabhu,
I don't know the answer to your question but thank you for reading this answer.
kv
Khozem Vahaanwala
Saify Ind
Bengaluru, India
December 6, 2019
A. I suggest you have a look at this page and choose the best fit for your application
"50 grades of stainless steel"
Kind Regards
, BEng.
ESPV - New Malden, London, UK
April 16, 2020
A. Have you considered a hard coating such as electroless nickel? It has excellent corrosion resistance and its hardness is 48-52 Rc. With an adequate pre-treatment it can be applied over your actual SS parts.
guillermo Marrufo- Monterrey Mexico
April 17, 2020
