Low temperature limit for zinc plated parts
Q. I have seen a lot of information regarding high temperature limits for zinc plate. What about low limits?
I have a customer that is immersing zinc plated parts in liquid nitrogen pre-installation and they are experiencing the plating peeling. Is this caused by the low temp?
Bob Newkirk
Adept Fasteners Inc. - Valencia, California
May 24, 2018
A. You would have to check the thermal expansion/contraction of the steel and zinc.
George Shahin
George Shahin
Atotech - Rock Hill, South Carolina
June 13, 2018
June 13, 2018
A. Hi Bob
The actual low temperature is unlikely to be the root cause.
Thermal shock is a well known test for plating adhesion and going from room temperature to liquid nitrogen is a pretty extreme shock.
You should look at the pre-treatment of the parts and particularly confirm that they pass a water break test.
