What to replace chromium trioxide with in Rust Converter
Q. I have a rust converter
⇦ this on
Amazon [affil links]
formulation that contains phosphoric, nitric, Teric LA8, butyl icinol and chromium trioxide.
I would like to replace the chromium trioxide with a less dangerous chemical.
What would you suggest?
manufacturer - Queensland Australia
February 2, 2018
February 2018
A. Hi. I certainly agree that you should try to get hexavalent chromium out of that formulation. How about simply leaving it out?
Do you know what roles it plays? It is an oxidizing agent, of course, but you already have another oxidizer, nitric acid, in the formulation. Do you feel that the chromium provides corrosion resistance, or perhaps helps protect any galvanizing remaining on the treated surfaces?
