UV Reflective paint
Q. I am building a light box which will have six UV CFL bulbs outputting at 311NM.
I want to paint the inside of the box.
I need a paint solution that diffusively reflects down to about 300 NM.
Its for home use, so I need to keep the costs down and non-toxic.
Any ideas out there? Thanks!
- Jacksonville, FFlorida
December 1, 2017
A. Hi Steve. If you can build the light box out of aluminum, I think you'll find that it meets all of your needs well. A quick sanding will probably make it diffuse enough.
December 2017
Thanks Ted,
I am limited to a wood frame.
I did some research and apparently PTFE sheets are diffuse reflectors.
I found a place on line called eplastics.com that sells sheets in various thicknesses.
So far that looks like my best bet.
Steve
- Jacksonville, Florida
December 7, 2017
