Please forgive the very slow page loading. We are suffering a Chinese DDOS attack thumbsdown it will pass.
Upper thickness limit for cyanide brass plating?
Q. Good morning all!
Thanks for taking the time to read this post,
We currently use a proprietary brass plating salt for basis decorative plating on typically previously nickel plated castings.
We currently have a production idea for an item that we wish to electroform and wondered what the practical upper thickness limits are for for such a process? I understand that this is a pretty inefficient process and would take an age to build any appreciable thickness but is there an upper limit or is it purely a case of time and keeping the solution in check?
Our process would basically be - brass plate mandrel (ideally to circa 100microns, acid copper to 1000microns and then remove from mandrel.
Am I missing a trick, would there be a more suitable process for thick brass plating?
James Yardley
Engineering Company - Essex - England - UK
October 24, 2017
