Powder coating on Aluminum Zinc (Aluzinc) coated sheets
Is it feasible to powder coat on Aluzinc sheets. If it is possible, guide us with the method.
Siva
- Chennai, India
October 23, 2017
A. Hi Sivaraja. Although you should certainly check with the Aluzinc supplier, I can't think of any reason that powder coating would be inappropriate.
Although a zinc phosphate pretreatment should be workable, those suppliers who reveal their pretreatment seem to be using chromate conversion coating, which sounds ideal for a material with high aluminum content like Aluzinc. Good luck.
October 2017
