Can gold be recovered practically after plating shop fire?
Q. There was a fire in a gold plating shop and the plating line was destroyed during the fire. The cause of fire was a short circuit. The plating shop was off-duty early morning but the previous night the plating shop was kept ready to operate the next shift. Entire line was destroyed as fire turned out to be a little fierce. There was a stock of gold plating powder containing 2kg of gold kept there for the processing. Is there a possibility that gold plating powder may have evaporated during the fire or would it have still remained for any salvage recovery? The temperature which might have reached during fire seemed to be around 400 °C. Can someone advise if it would be worth putting effort to salvage the same.
Sharad ShahMOEF reg'd recycler - Bangalore, India
October 15, 2017
A. It should be possible to recover the gold. 400 degrees C may decompose the gold salts, but the gold should still be there, Lyle Kirmanconsultant - Cleveland Heights, Ohio October 17, 2017 A. Hi Sharad ![]() Geoff Smith Hampshire, England October 17, 2017 |
Thank you so much. Your guidance has been really helpful for my client to regain some confidence.
- Bangalore, India
October 17, 2017
