Cu Anode balls Utilization Improvement in Electroplating Process
We are a manufacturing company which utilizes Cu and Sn electroplating process in our backend steps. I would like to solicit tips on how to improve utilization of our Cu and Sn anode balls (w/o reducing plating thickness) or improve tool UPH or improve plating uniformity. We basically use a typical electroplating setup with Cu anode balls (in Cu bath) and Sn anode balls (in Sn bath). Our cathode substrates (held by plating jigs) sequentially go through Cu bath then Sn bath via belt carousel. Very generic inputs are welcome. Appreciate your feedback. Thanks.
Jun Idjao
- LAGUNA, PHILIPPINES
October 3, 2017
Usually available on eBay; sometimes on AbeBooks or Amazon
(affil links) mfg_online
A. Hi Jun. What do you mean by "improve utilization"? Do you mean you throw away the anode balls when they become small, but want to know how to not have to do that?
What is 'tool UPH' -- units per hour produced by the plating line? You want to increase the production rate? Do you have the rectifier power necessary? Have you run any Hull Cell ⇦ huh? s which indicate that higher current density will not be a problem?
Uniformity refers to what, the plating being thicker in some areas and thinner in others?
By "belt carousel" are you saying that the parts are inserted into pockets in a continuous belt sort of like bullets are inserted into a bandolier? You are plating some sort of electronic components?
Do you have any plating books on hand which we can refer you to for discussions of these topics? This forum can be helpful in helping you locate reference material, and in answering highly specific questions, but for very generic coverage of plating issues, a paragraph or two here is no substitute for a book or a training course  🙂
October 2017
