Can etched & de-smutted parts be delayed before anodizing ?
Q. Hi Everyone,
I understand it's best to proceed from cleaning through to anodizing without stopping between steps, but IF it's necessary to delay getting the parts into the anodize tank after rinsing from de-smutting, can the parts be held-up for an hour ?
If so, what's the best way ? Keeping submerged in a clean tank of DI water ?
Thanks in advance !
- Adelaide, Australia
August 9, 2017
A. The parts will be fine in a clean tank of water for an hour or so. I have pulled racks to add or remove masking and then entered anodize. I will do a drop in a final rinse first to verify I still have a clean water break free surface on all parts.
Ryan Underwoodprecision protective coatings - Savannah, Georgia
August 25, 2017
OK, thanks Ryan.
August 28, 2017
August 25, 2017 I wanted to add to this: - Riga, Latvia If I were you, I don't prefer even DI water. If flight bar dwells (long or short time, 10-15 min./3-4 hour) in bath (clean or dirty doesn't matter) corrosion risk will be highest, probably you will see spots like "snowflakes". Alaattin tuna- TURKEY,sakarya August 26, 2017 |
